Salesforce
Using Scheduler in CCleaner 7
« Go Back
Information
using-scheduler-in-ccleaner-7
Alan J S
CCleaner
Summary
Article
The Scheduling option in CCleaner 7 allows you to set up automatic cleaning routines to keep your computer optimized. To use the scheduling option, follow the steps below:
  1. Launch CCleaner 7.
  2. Click the Settings option on the left-side of the screen.
  3. In the Settings window, under the Scheduling tab, move the slider on the right-side next to Maintenance every 2 weeks.
  4. If you want to create a customized schedule, click Create a new schedule under Customized schedules.
  5. You can also create the following schedules according to your needs.
    • Daily Maintenance
    • Weekly Maintenance
    • Startup Maintenance
  6. In the Create a new schedule screen, fill in the following details and click Save Schedule.
    • Frequency
    • Day of the week
    • Time
    • Type of Clean
Powered by
