Salesforce
How does the Software Updater work?
« Go Back
Information
how-does-the-software-updater-work
Alan J S
CCleaner
Summary
Article
Software Updater operates in a two-stage process. It scans your computer for available updates for software and helps resolve them.
1. Scans your PC for available updates:
Once Software Updater completes the scanning process, it puts software into either the Outdated software or Up-to-date software tabs in the Tools > Software Updater part of the CCleaner app.
2. Updates all outdated software by default:
Software Updater finds out-of-date software, preselecting it to be updated by default. To change this, you can tick or untick the checkboxes next to the software's name.
Click Update Selected (once you've selected the software you want to do this to) and CCleaner automatically retrieves and installs each update.
Powered by
