Salesforce
How do I include custom files for cleaning?
« Go Back
Information
how-do-i-include-custom-files-for-cleaning
-1519573102
CCleaner
Summary
Article
You can choose specific files, folders and Registry entries to be included or excluded from CCleaner Cloud operations.
Note: If you add an inclusion, you must select the Custom Files and Folders check box on the CCleaner screen.
You can add as many Include statements as necessary by repeating the following process.
To include files or folders in the CCleaner process:
  1. In CCleaner, click the Options icon at left.
  2. Click the Include section.
  3. Add a new include statement by clicking Add Item. This will load a dialog box:
  4. You can then select your items by:
    Field
    Explanation
    Include
    To choose a drive or folder to include, select Drive or Folder and enter the location path.
    To choose a file to include, select File and then enter the location path of the file. You can only add one file at a time.
    File Types
    This selection is only relevant when you have selected Drive or Folder.
    By default, CCleaner Cloud will include all files in the selected drive or folder. You can choose to include only files of a certain type. To do so, click File Types: and type one or more file extensions. For example,
    • *.doc to include all .DOC files
    • *.exe;*.bat to include all .EXE and .BAT files
    Options
    This selection is only relevant when you have selected Drive or Folder and have selected a folder.
    If you select Include files only, CCleaner Cloud will only delete files located in the folder you have included.
    Selecting Include files and subfolders will cause CCleaner Cloud to search all sub-folders within the selected folder for the files to be deleted.
    If the Include files, sub-folders and the folder itself option is selected CCleaner Cloud will first delete all the files that match the criteria, just like in the previous option and after that will delete every empty folder within the included one.
Powered by
